Cams for my 240sx
slowpoke2005
Car: 240sx se
ok i have a 1995 240sx se with the Ka with twin cams and 16 valves. I was wanting to know what whould be the best cam for the most horse power and torqe. I have some good Headers, 3in catback and a new k&n air filter. What would be the best cames for the weekend racer at the drag strip, and a daily driver diring the week. Thanks.
oh and i checked the pluges today and when i pulled the wires out from the motor the out sid was brown like a rust color is that normal or not ?
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
how much you want to spend if you want cheap the Earlier s13 cams were better than the S-14
slowpoke2005
Car: 240sx se
i wouldnt want to spind more then 650 or 700 would be the most i could spind on a both the cams.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Cams are kind of a thing you have to research for yourself because you're the only one who knows just what you want. Some will help out low end and hurt top end power, and vice versa. PDM and JWT cams are probably the most popular, and I think they both run around $5-600. Im pretty sure PDM has a dyno chart on their site, so check that out.
slowpoke2005
Car: 240sx se
THe JWT cam is .390" LIFT / 275 DEG
and this is the pdm cams Intake 221 duration @.050� .379 lift; (272 advertised duration), .380 lift; Exhaust 231 duration @ .050" lift, (278 advertised duration), .390 lift.
okwhere can i find some more cams. I know its going to be my disision on which ones to get but i need som advice. here is what im looking for is a set of cams that will give me a good power boost and use a good powerband for a road race or drag race. If i need to upgrade anything else with the cams plz let me know thanks for the help.
sunnys14
Car: S14
s13 cams from 91- early 93 are good. they make you lose a bit of low end but it makes you gain in the high end. that shouldnt cost you more than $100 and 2 hours of your time. direct drop in
slowpoke2005
Car: 240sx se
can just new cams add 40-50 hp to your car?
fbodtrek
Not bloody likely....More like 10-20 hp tops, more with headwork and tuning though.
InsanityInc
depends. For a 2.4L, 40-50 is out of the question. If you had a 427 or something, that would probably be more reasonable.
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Your best bet would be to get in touch with Jim Wolf Technologies either by phone or his website. I live in near El Cajon, CA where his shop is located and for $878.00 he installed cams and retuned my computer. His cams don't really pull until close to 4000rpms so he resets the redline for 7000rpms which as you know will give you an extra 500rpm pull. He also tuned the ECU and eliminated the fuel cut so now your car can go faster than 115mph or so. I have run against my wifes BMW 325i and we were doing 138mph. Bottom line, cams won't help to their full potential unless you tune your car to use them. It may be a little pricey but if you go with another set up at least get your ECU tuned when you get the cams.
se-rious
Car: 240SX SE S14, FC Turbo, b-13 SE-R, AE86 GT-S
i love the engine bay on the white s14.
ddgsxr504
Thanks man, I try to keep it pretty clean. My wife is looking after her while I am over here in Iraq though. I usually just spray the engine bay off while leaving the motor running with a pressure washer. I have a bunch of new goodies to go underneath there. Being deployed pays big so I bought a nissan JDM strut tower bar to replace that puny Trust (Greddy) one. If anyone is interested I will sell it for $40 shipped anywhere in lower 48 states when I get home.
