cams,ecu,injectors,exhaust
94q45guy
Car: 94 q45
does anyone know if its possible to get cams reground to different specs and if u get an ecu from jwt or from anywhere if a slight lopy idle would make the ecu go crazy and throw out random codes thanks jerrod
TXCumtrensh
Car: None
No, a lopey cam will not throw crazy random codes.
you might get a missfire code, from the AFR's being rich or leaner than normal... thats about it.
94q45guy
Car: 94 q45
anyone know the stock cam specs and size of the stock injectorsthanks jerrod
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Try asking this question in the VH and VK forum. It is specific to the 4.5 and 4.1 litre engines. You might even do a search, and find cam specs. It has been discussed before.
You mention exhaust in your title, but have not said anything. A couple of us have done custome set-ups, and a lot have replaced the rear muffler. Not much of a gain with the rest of the engine stock, but necessary if you plan to do more. I would consider it a first step in building a tuned system. I think the best improvement would come from a tuned set of long tube headers to replace the factory manifolds. I think as much as 8 to 10 HP could be gained there.
Q45tech
90-95Q = 248/248 with 9.9mm lift 8 or 28 dergrees overlap
35lb or 370 cc injectors enough for 448 HP at 80% duty cycle
94q45guy
Car: 94 q45
anyone know of anywhere that regrinds cams and where to buy stainless pipe for cheap and how you can weld stainless because i know that you cant with a normal welder and also would injectors make a difference with an ecu or would it just be the same to me it seems like it would be just like puttin a larger carb on a carbeurated engine im not that good with fuel injection though thanks jerrod
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You need to post up in the VH forum.....
You can weld stainless iwth a mig or a tig, you just need use tungsten.
adding larger injectors wouldnt really do anything if your going to stay N/A. One thing you could do is make sentances in your posts.....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
tryalittlepuctuationandcapitalizationtomakeyoursentencesmorereadable
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
There is a special weld alloy developed for automotive stainless exhaust systems (304). It is SS409. Normally available in flux core rolls for MIG welders. All the muffler shops use it cause it works and doesn't crack. It provides the best weld zone ductility and crack resistance. Standard stainless weld materials and techniques do not hold up under the vibration and thermal cycling environment and will crack at the welds. I have a 40# roll of 0.035" dia of the stuff. Used about 10' of the roll. Offers?
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
Texasoil, who makes the stainless flux core that you are using? I need to get a 2 lbs. roll for my little mig welder.
Does the flux core that you have use a shielding gas or is it a pure flux core (gasless)? Thanks.
- Siju
defrag010
isky, comp, and crane will all do re-grinds.
