looks like ill be making a call to level ten for the transmission then...thanx driver....im going to look into those rotors and i guess ill just get new stock calipersdriverdriver wrote:The QX4 transmission won't fit the J30.
Brembo rotors are a nice brake upgrade, you can feel the difference. Nobody makes custom calipers for the J though.
yeah i just have to figure out how to do the twin turbo swap...theres a lot of relocation needed to be done there...Midwest_Drift_Shop wrote:There isn't much you can do with the J's transmission, and the RE4R01A isn't a great transmission to start with, about all you could do is take it to a professional transmission builder that has alot of experience rebuilding R4L60E's and other performance automatics. They should be able to build an RE4R01A to handle better power, and possibly a shift kit for improved shift times.
Go with Brembo rotors and possibly Z32/GT-R calipers(if your wheels will clear them), and go with Hawk pads. The Z32 calipers should be able to fit on the J, I don't know if anyone has done that before.
If the car is your daily driver, i wouldn't go with performance cams, it would just be a waste of time and money. If you were to go that far, might as well build the bottom end while your at it. Some forged aluminum pistons and stronger rods would be nice, plus if you go with lighter pistons, it will remove a little rotational weight, might gain 2 or 3 hp from that alone. Although the stock internals would probably handle the performance increase from the cams, injectors and tunes. It wouldn't be a much larger number than from stock, if you want some nice HP numbers, forced induction would be the way to go.
i dont quite follow...rear mount turbo...please explainMidwest_Drift_Shop wrote:Rear Mount Turbo... Look at the Q45's, there are a few that have that setup. The stock muffler on the J is large enough to get rid of and place a nice turbo setup there.
Just an Idea.
He's saying that even with bigger cams, you will still not be running out of fuel with the stock injectors since they do not run even close to 100% duty cycle with a stock engine. You will probably not be maxing out the stock injectors with the upgraded cams.kbflip02 wrote:
and wouldnt i need those bigger injectors since im running upgraded cams?
He wants to add power to his N/A car. He doesn't want to turbo it. I agree though, gains would be minimum compaired to cost/labor to install cams.Q45tech wrote:Still down understand what you think you will acomplish by replacing the 4 cams? If you super/turbo the oem stock cams are fine and more duration/overlap may hurt power or at least reduce gains on a per psi basis.
I've already told you my opinion.kbflip02 wrote:this is correct thank you scott...so what in your opinion do you reccomend....i figure if i do the cams ill have the intake ported and also upgrade the throttle bodies and injectors...what do you think...
