Camber
motoxris
Car: 92 240sx coupe
Just wanted to ask what all the other intermediate drifters are running on there front and rear camber settings. I use 3 in the front and 2 in the rear, with .25 toe out in front.
Post years drifting and settings.Thanks
fourLUG_hero
-6* front.1* rear.
Hella drift style y0.
motoxris
Car: 92 240sx coupe
does that function well?
PEZi
i don't drift... but just figured i'd give some info as well because i autocross...
my autocross setup is -4 front 0 rear... it helps the rotation needed to get through corners
motoxris
Car: 92 240sx coupe
Any one else?
TheBlaiant
Car: Slow40sx
Once I get a job agian i'm gonna run -852189465 degrees front and rear
sr20power
Car: S14 Zenki
TheBlaiant wrote:Once I get a job agian i'm gonna run -852189465 degrees front and rear
Sweet and now we can all understand why you are looking for another job! I'm just a beginner and run -2 up front and -1 in the rear with toe at 0. I think my caster is about 8-9 up front.
From that point its pretty much adjusting tire pressure and dampning. I'm a noob.
poshatch
Car: p.o.s. 1990 240sx hatch
im running -2.5 in the front with my camber plates maxed out ( ) and -2.5 in the rear although 3.5 look way better
im a noob too so take into consitteration whatever you want
what coilovers you running to get -3 degrees in the front?
