Camber
Anand
Car: 95 Nissan 240SX
When installing the Eibach Sportline springs... would I need to correct the camber in the front?
Aries
Car: LT1 240SS
Not usually in the front, but sometimes in the back.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
If you havent already gotten one, your alignment shop will need to install a camber correction kit. You will need to correct camber in the front, it is adjustable there. I do not believe it is adjustable in the rear.
GoofyATX240
Its adjustable in the rear not adjustable in the front thats what happened with me.
Anand
I heard that you can't correct it in the back as well. The front is the only thing that can be corrected...but I could be wrong... I have been looking for camber correction for the rear and all I find is for the front, which makes me think that front could be the only thing that can be corrected.
GoofyATX240
The rear can be corrected the reason u find camber kits for the front is because the front isnt able to be corrected...the front you can do the toe in on the rear u can do the toe in and camber.
Lepchitz1
Car: Cars, and LESBIANS!!!
HOW DO I FIX THE REAR CAMBER!!!!
PabloHoney
Front has adjustable camber. There is a lobed bolt in the front that controls camber. I had it adjusted after I did new struts just to be sure that it was right. The rears are also adjustable. The FSM says the front is non adjustable, but the alignment guy I took it to did it for me.
Lepchitz1
how do you adjust the rear?
