ldstang50 wrote:Try adjusting to 2.0, that will surely help with outside wear. Whats your car doing in a corner now? Understeering, oversteering? If you tend to push even after your alignment, I'd decrease the setting on your front bar. I'd also pull out camber in the rear. Currently I run -1.8 and wish I could run less. Your toe sounds fine.
currently im running stock sway bars with alignment settings i mentioned above, and the car is very neutral. it has a tiny bit of oversteer, but barely enough to notice. I rather it that way than have understeer.
My question now is, are Anti-sway bars even worth the money? The adjustable Hotchkis's i want are around 340$. But the Z isnt like a 240sx, the stock front sway on a z is already huge. will there be that much improvement over stock? also it was mentioned that stiffer sway bars will effect camber, by limiting the body roll you limit the amount of positive camber due to body roll. i know this is true, but how about some first hand experience, ldstang50? Maybe i dont even need to adjust my front camber.
One thing i didn't mention is that i have front an rear wheel hop due to improper spring rates. either the springs i have aren't properly designed or my aftermarket shocks (not adjustable) arent stiff enough for the springs.
rear wheel hop is only felt when doing a burnout in a straight line, and front wheel hop is only felt when understeering into a corner (when the front wheels are sliding). But under these circumstances, its REALLY bad. the feels like the car is going to fall apart. But since it doesn't happen all the time, i would only be interested in fixing this if it would actually benefit performance.
as you can see, i have a limited amount of money, but alot of places to spend it.
Modified by redsx13 at 11:57 AM 4/7/2009
