Camber shims??
Home of the Nissan Cube forum and CubeDriver.com
chompsticks
Car: ???? Nissan Cube Krom
So I might need to install camber shims and was wondering how hard are they to install?
damian666robin
Car: 2009 nissan cube
if is only rears it should be very easy and fast
501
they are very easy, i can do them in 15-20min. basically you just need to do the following
jack up the rear of car
remove wheel
remove 10mm nut for abs sensor
remove the 4 14mm nuts on the back of the hub
pull the hub off axle
put the proper side shim in between hub and axle
line up holes and put the hub back in
use supplied spacer to give the supplied 17mm bolts a flush spot to tighten down
put the abs sensor back in
tighten evrything
put wheel back on
what was the offset and width again for your wheels? if i remember right yoou shouldnt need the camber shims
chompsticks
18x8 +25 in the fronts, with the coilovers set on max neg camber, although it's not too much negative camber. It's just perfect in the fronts.
right now it's 18x8 +25 in the rear, I want to add some camber to the rear to push the rears out another 5 or 10mm, but since the fronts don't poke much anymore I might be good at just leaving it at +25 in the rears. (Still rubs with a full load in the rear)
Tires are 215/35
Will see though, I will get pictures up sometime this weekend and see what you guys think.
501
8" +25 is perfect up front you shouldnt even neen the negative camber. the rears you are rubbing where the body meets with the rear panel with that tire size if you put a 195 on the rear you should be able to get another 10mm of room
cant wait to see the pics!
chompsticks
They make a 205/40/18 and then 215/35/18 no 195s
205 made the car a little too high, 215 make it a tad bit lower.
only tire options available that are useable for the cube and 18x8 wheels. I should have waited to find some 18x9s instead...
I need camber shims so I can correct the rear toe and add a smidge of camber. My tires wear out faster in the rear than the fronts.
Heres a pic!
501
looks good!, i am looking to getting my 15" wheels and fenders that close
damian666robin
have you tried the shims already? rite now i am using those unless you use a -3 kit from the camber doctor, a -5 is to agressive and will cost you a lot of tires trust me i had -5 :facepalm:
the regular shims give you a -1.5
you could mix 2 kits for each side and create a -2 i think thats more what i need instead of the -1.5 cause once i put a nice load on the cube it still rubs
chompsticks
I haven't had them on before, I might not even add anymore camber, I think a fender pull on the rears would be just perfect. Only needs to be like 1mm or 2mm pull.
Although I can use the shims to correct the toe, it's bad enough that my right rear tire wears out the fastest.
Here's another shot with the wheels. ;)
damian666robin
dont pull the fenders man you gonna ruin them i did and not only will crack the paint but is gonna bend the metal making it look really bad
just get the shims first and give it a try, it will give you -1.5 and tire wear wont be much at all, overall you are always going to have that issue with 18" wheels no matter what i dont know how that guy on the cube forums is having the nerve of runing 20" wheels 18" is big enough to deal with it lol!
chompsticks
If you use a heat gun it should be alright. The paint has flakes and burned already anyways.... Just like 501s. ;)
501
just so you know the rear with my ride hieght is at -1.4 degree camber. this is without any shims
chompsticks
Thanks! I found out that the toe needs to be corrected by
.5 decimal inches OR
.99 decimal degrees.
At least at the ride height I am at, which is 22 and 3/4 inches. from ground the fender.
My passenger rear toe is worse than drivers side.
501
mine is the same way also, passenger rear tire wear faster also at 22 3/4" ground to fender
thanks for the info!!
next up is getting the axle vibration fixed!
chompsticks
No problem!
Is the axle vibration what you get when you are making sharp turns? I notice when I am turning and accelerating that it feels like there is something loose in the steering.
501
yea that is it, gets a little worse when you go really low up front
chompsticks
Ahh, then I am having the same problem... It seems to be getting worse for me, but it might just be the fronts settling in a little bit.
If you guys think you can adjust toe AND camber on your own, you're more skilled than me.
Take it to an alignment shop, spend the $70 and get it done right.
p.s. I was one of the first people to use the shims on a Cube, and it's a colossal PITA. The formula for getting the toe and camber right is complex as hell with the dual ring shims.
chompsticks
:P
It's not too hard to understand. As long as you know your numbers for the rear and know stock numbers then you just adjust accordingly to what you want it to be. So if you wanted to change toe by 1 degree and camber by 1 degree you just follow the table and line up the numbers. My problem with them is the fact that they give you less offset. Even if I adjust the toe correctly I would have to add more camber otherwise I rub like crazy. I have to get a new set of shims now because of that.... :(
How are they affecting offset? I mean, the thickness of the shim isn't much.
Might be time for different wheels or different tire sizes (which I did to eliminate the fender rubbing).
chompsticks
Thickness isn't big at all, but it did affect it ever so slightly... I am perfectly flush in the rears, If i put 4 people in the back I will rub and with the shims I was just rubbing without anything in the rear. That just means i need to add some camber, but I am not really one for the aggressive camber look and plus straight line driving gets tricky.
Yeah, I'd sacrifice some "flushness" for functionality.
501
i paid 150 for my alingment, by a guy who who does mostly race cars only. he can correct the roll center the axle vibration along with the rear toe and camber...he has shins that are 10th's in thickness. his concern when adjusting mine was that the rear wheel bearings would bind up.
when i brought my car in his first question was "do you want it to not rub or you want cornering performance or both" i knew i was at the right place...lol
chompsticks
we need places like that here on the east coast!
protoculture
Car: Nissan Cube
Love your cube man. Can you forward me the details on the RIMS and tires of your vehcile?
rwb
Car: 2011 Cube
He sold it a while back. I doubt he will respond to your question.
protoculture
Car: Nissan Cube
Thanks for that!
rwb
Car: 2011 Cube
He still has a lot of pics on cardomain.
Return to “Cube Forum”
