ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Mon Jul 26, 2004 11:57 am
Well, in the rear you can adjust camber stock, but, depending on how much it is lowered, you may not have enough adjustment built in. In that case, you would need some kind of adjustable control arm.
In the front, stock, there is no camber adjustment, but with the strut suspension, you don't gain negative camber when you lower the car. If you want to adjust camber up front, you will need camber bolts, or camber plates.
