camber question!
240twoforties
Car: 91 240sx hatch!
hello all. i drive a 91 hatch and in a few days i was gonna go to down to this local auto hobby shop and throw some skunk2 lowering springs on it. i talked to the mechanic who i always get to inspect my car and he said i should get a camber kit if i was going to lower the car. so i am just curious if the kit is necessary, because the drop is only gonna be like 1.8 inches all around i think and i've never seen a 240 with negative camber after slightly dropping it on springs.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
You probably won't need it. If anything, some negative camber is a good thing.
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
scotty's exactly right, youll be fine
240twoforties
that's what i'm saying i'm too poor for coils and i got the springs for free haha. will it affect aligning it at all?
scotty-2-forty
240twoforties wrote:that's what i'm saying i'm too poor for coils and i got the springs for free haha. will it affect aligning it at all?
Always recommended that an alignment be done after any suspension changes. If anything, they might just be able to bring that (-) camber back into spec too.
gumby74
The correction kit will most likely consist of a pair of eccentric bolts that you can find online for unedr $30 shipped to your door. If you are in fact a broke (no disrespect) student the kit will save you on tires. Some camber is good, factory spec will yield better results financially speaking.
poshatch
Car: p.o.s. 1990 240sx hatch
keep the natural camber
if you plan on doing more suspension mods...this is the time for a lifetime firestone alignmnet
its 150 for a normal car
but 250 if you modded the suspension, so pay for it now, then mod it and save yourself 100 bucks AND have lifetime alignments! FTW
car nut
Car: GT500.
Toe will hurt you more then camber. If you drive your car hard, negative camber wont be an issue and your tires will wear evenly. Toe is what will eat your tires.
poshatch wrote:keep the natural camber
Really? Theres a Firestone near me, I gotta check this out.
poshatch
car nut wrote:Toe will hurt you more then camber. If you drive your car hard, negative camber wont be an issue and your tires will wear evenly. Toe is what will eat your tires.
yeah its pretty sweet ive used it like 4 times in the last 2 months hahah
i need one right now actually...
since i lifted my car up like an inch (skid pad i bent a tie rod and im tired of dealing with the bulls*** that accompanies DDing a slammed car)
