JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Thu Aug 19, 2004 10:33 am
Im not sure about the clearance issues, if they are designed to work with stock strut/spring combos, then there is no reason at all it wouldnt work with lowering springs. Lowering springs make the car lower by the springs being shorted, absolutely nothing changes above the upper spring seat. With the camber plates, you are replacing the upper strut mount and gaining the ability to slide the top of the strut in and out, creating more or less camber as desired. There should be no reason that you hit anything, since the plate itself remains stationary. I would say that once you install them, take them to an alignment place that is pretty cool (like me, i love workin on imports, esp if they have tuner stuff on them that make aligning them easier!) and see if the tech can set the front at 0 camber so you can mark it on the plates. Then try and get a reading with the plates maxed out positive and negative, so you have some reference points to play with on your own. Most shops wont jump through these kind of hoops for free, so be nice, be polite, and be prepared to pay extra.
I just purchased some JIC upper camber plates, but am having problems installing them (they were used, and probably missing peices). If i can get them to work, i will be all set. JIC rear upper control arms for rear camber, JIC tension rods for front caster, and JIC upper mounts for front camber. Complete adjustability coming soon!
As for adjusting them once installed, you will want to have most of the weight off the wheel you are adjusting. If you leave the car flat on the ground and loosen the adjusting bolts, get ready for them to slide all the way negative under the weight of the car. So lift the corner by the frame or crossmember to remove weight from the wheel (think of letting the weight of the wheel pull the top of the strut out, making positive camber....).
Hope this helps!
