Camber plates and suspension
salvadoranninja
Car: 89 240sx
hello everyone i am new to this forum thing but i'll give it a try. I currently have a set of KYB AGX shocks and Tein S springs but would like to buy camber plates. I was interested in buying the Tein camber plates but the guy @ frsport told me that the Tein camber plates will only work on a coilover setup,and for some reason there are also 2 different part numbers for the same part (one i got from JDM monster the other from FRsport) . Is there anyone here with the same setup? if so do you know the part number, and is there any little issues i should know before buying these camber plates, or maybe other camber plates that may be better. thank you everyone hope to hear from you.
Cone Junky
Car: S13 fastback
BMW e46 328i
I had the same question until I bought a set of used struts and springs that had a the TEIN camber plates mounted on them. They worked fine and they look like the exact same plate that came on my coilovers. I was even able to push them all the way over to full negative without any issues.
