blindsnyper »
https://forums.nicoclub.com/blindsnyper-u77442.html
Wed Jan 12, 2011 3:48 pm
a camber kit is used to correct the negative camber that comes with lowering a car, which will reduce caber wear on the tires.
**UNLESS**
you have a low offset wheel and are using the negative camber to tuck the tire inside the fender, which will wear out tires fast.
