gachrist3.5 wrote:ahh my bad bro..got busy and kinda forgot about this forum for a lil...
anyway the drop is awesome..im loving it..ill post pics this weekend...
did not even use the camber kit...it was just for the front which needed absolutely no adjustment at all so i didnt even use the kit
the back however was out of wack..but there is the ability to adjust camber and toe in the back...but not to have it dead center..so it could be enough to be adjusted within specs...just not dead on like the front...my back wheels have a little bit of negative camber, i believe (tucked in on the top more and flared out on the bottom, nothing really noticeable though and should be fine with rotation of the tires)
Yeah, I think we kinda told you. I know from experience when you drop a car, you're gonna need camber kits but for the eibach prokit, it's such a small drop that it doesn't even warrants it. My camber was very close to spec and there was no tire wear issues after 5K. The Toe is what is really important here and there is adjustment that corrects it.
