digitalbow »
https://forums.nicoclub.com/digitalbow-u39338.html
Fri Jul 25, 2008 10:34 pm
I hope it's not too late... but I just wanted to correct some of the confusion here about camber. (Keep in mind that toe can also affect tire wear)
0 degrees is ideal for a regular street car. Your front wheels are the ones that are going to be most susceptible (as most kits change the spring rates/ratios more in the front) to negative camber, not the rear.
You should get an alignment and check the camber any time you change your wheel/tire combination (like stepping up to a 20" setup for example) and also when changing your suspension (aftermarket or not). It will not always be readily apparent that you need to bring it back into spec until you see the effects.
If you care about longevity of your tires, reducing stress on other components, and straight-line performance then you want 0 degree camber.
If you are doing auto-x, consistent aggressive maneuvering, or want stupid "VIP" look and have money to burn on new tires every 3 months, then negative camber is fine.
Camber with any inclination on the drive wheels will just wear them down unevenly. Camber on non-drive wheels can, in addition to the above, create waves in the tread which causes vibration and noise.
Positive camber is typically something we do not have to worry about, as lifted trucks and cars running goofy small/skinny wheels would.
So, do you need a camber kit? Probably not, but if you can't get back into spec without it, then yes.
Modified by digitalbow at 3:31 PM 8/7/2008
