gumby74 wrote:Fork out for the appropriate adjustable links m'man. The stock bolts do not have the kind of adjustment capability that the average enthusiast needs. They are good for about 1 1/2- 2" of lowering or, as you have come to find, 2* of correction.Look into adjustable ruca, and possibly toe links. Though I personally think the stock toe rod is adequate.
Like gumby74 said, after market links are definitely worth the money. Look into spl parts, they make high quality adjustable links. Although if you install a RUCA and and plan on using it adjust more than 2 degrees, it will toe out the rear wheels to the point where the stock toe arm isn't long enough to adjust it back. I think if you plan to get RUCA you should count on needing the toe arms as well.
