Camber degrees please
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
whats the best camber degrees with a shock/spring suspension?
now its at -0.7 in front and like -1.5 in the back
Modified by Seto at 9:41 AM 10/19/2006
180fan
Car: 89 fastback
that depeds on your preference. adjust it a bit and see how you like it. Some folks have special requirements like fat wheels and low offsets that force more negative camber.
S3t0_S13
well my tires are 17X7, so not that wide, but overall, im not sure how the angles are supposed to be, the front is less negative then the back, and ive been told thats bad for handling, true?if so what setup should i have, for best tire wear and handling in ur opionion
