dhope240 »
https://forums.nicoclub.com/dhope240-u5538.html
Thu Feb 27, 2003 5:47 pm
Ahem, no need to get mad. I am not spreading mis-information, I am speaking from first hand experience and words of many others. Please explain to me why a couple degrees of negative camber would have an adverse affect on tire wear, giving that the toe is set correctly. Talk to any alignment shop that is knowledgable and they will confirm this. To put things in perspective, if a car were to have 0 camber, the tires would wear adversley, unless of course you travel in a straight line everywhere you go....
In conclusion, lowered cars that are daily drivers will not need to get any camber correction kits, just a good alignment will suffice. Camber can still be adjusted to an extent using the stock bolts. I do agree that excessive negative camber would cause tires to wear quickly, no opposition on that subject.
Daniel
