I am planning to replace the font struts on my 2010 Rogue soon. To begin with, I saw couple of YT videos showing the entire process.
Everything seems fine until the golden word "alignment".
As per Nissan service manual, camber and caster cannot be adjusted,but only toe.
So what really happens in this case?
Ok. I thought this topic will be an interesting one to discuss and could answer very very important questions on suspension dept.
below are my concerns w.r.t this project and would like to know your valuable suggestions
1.the top two strut bolts easy to remove ,but 3rd one is hidden under the cowl and PITA to get to.
i see the bolt could fall which needs entire cowl to be removed....PITA....Is there a simple method to remove and install it?
2. the top mount holes are oval and can be adjusted,so is it necessary to mark them before removing it?
In case if the first two bolt doesn't align with old marks ,does it affect camber/caster significantly?
Most YT videos doesn't focus on this part.
Will misaligned bolt cause measurement throw out of tolerance?
Its very difficult and lot of trial needed to cover previous hole marks looks like....what a PITA
3.Same case with 3rd bolt, how do we align its position (oval mark)? what a PITA...
4.Most mechanics simply prefer alignment once done, but what happens exactly w.r.t camber and caster at alignment shop?
Do they really adjust the tower bolts? How about knuckle bolts?
5. As toe is not affected here, is alignment necessary ? Wheel alignment is a serious business nowadays....???.
Please share your ideas/thoughts...it will definitely help a lot of good responsible Rogue owners like me.....
