No. D22's use cam washers on the upper control arm mounting bolts rather than shims. Rotating those bolts moves the egg shapped washer around and moves the upper control arm in or out. Caster is adjusted through differences in the front mounting bolt and the rear one.Reverend D21 wrote:Adding/Subtracting the shims on the upper control arms.
