Camber bolts needed with coilovers?
Dammitboy
Car: 92' Nissan 240
Hey guys, just curious, I have a pair of front adj. camber bolts laying around. I'm bout' to install coilovers on my S13, should I use the camberbolts or is this overkill?
Thanks!K
Slappy
Car: 1993 240 sx coupe
If your coilovers have Upper Pillow Ball Mounts then no you dont need camber bolts.
Search.
crackler
Car: ZOMG JDM TYT3
Pillow ball mounts??? Camber Bolts???
You mean you guys don't have eccentric bolts that control your camber and caster???
Ask the guy with gay car, that has a real suspension.
Like slappy said, if your coil overs come with camber plates/pillow ball mounts, there should be no need for the camber bolts, unless you are trying to do something weird, or you can't get the alignment numbers you need/want.
Modified by cracker at 11:04 PM 7/5/2008
