Yea my car is lowered. Around 1.5 inches. I just got new tires and i really dont want them to be worn by the negative camber. How and where is the s13 adjustable in the front?naed240sx wrote:Is your car lowered, or have you had it aligned recently with poor results? Im just curious why you feel that you need that adjustability. The s13 does come with front camber adjustability.
The Slotted Hole is supposed to be used for Scrub Radius Adjustment, is what I've been hearing alot lately, and it makes sense to me.naed240sx wrote:On my car, when the alignment shop does it, they just use the slotted hole on the lower kts mount. I think the stock struts have that slotted hole too. You may or may not have em depending on what model 240 you have.
The slotted hole is what the alignment guys have always used to adjust the camber on my car. I have seen them do it, and it does make changes to the camber. What is scub radius? How are you supposed to adjust camber on an s13 that doesnt have camber plates? I have always been told just to let the alignment guys do their thing, and mess with the camber plates yourself if you feel the need.McRussellPants wrote:The Slotted Hole is supposed to be used for Scrub Radius Adjustment, is what I've been hearing alot lately, and it makes sense to me.
The Camber plates are what you'd use to adjust camber.
Dont put the Eccentrics on the spindle. they belong on the inside of the FLCA. but the only reason you would need them with camber plates is if you needed like 4+ degrees of camber.
Oh... I thought I saw you say that you had KTS coilovers. In that case then that slotted hole will be the only way.naed240sx wrote:
On my car they were on the spindle stock (I have zenki)........McRussellPants wrote:Dont put the Eccentrics on the spindle. they belong on the inside of the FLCA. but the only reason you would need them with camber plates is if you needed like 4+ degrees of camber.
Zenki S14? Yeah... those dont have slotted holes I dont think. I'd think if you used them like that on an S13 with the slotted upper and eccentric bolt combo it would be really hard to set camber.brokeAs240sx wrote:
Where mine were installed:
front - top spindle bolt holding strut in.rear - ruca bolt on spindle.
