Camber bolt adjustment
ESPER
Wsup fellas, just got the eibach alignment correction bolts from tire rack for my s14's agx's. where would thes bolts? would they just replace the existing bottom bolts on the front agx's? thanks!!
ziggy682
Car: 1991 240SX Turbo
Yup. You can replace either of the lower strut mount bolts in the front with them. Basically, as you turn them, the strut will move in or out...this is how you adjust camber with them.
ESPER
right on, thanks!!
