Thanks QTech.
Q45tech wrote:1" of lowering increases negative camber by ~ 0.83 degrees. There are no front camber adjustments on 90-01 Q45, The oem rear adjustments usually have less than +0.5 degrees of range.
Considering tire wear, braking and handling the worst thing one can do is lower body height by more than 0.75>1.00".
I thought that lowering the vehicle would improve steering and braking (lower center of gravity is good no?). The springs I ended up getting are Espelirs because I tried in vain to get my hands on Eibachs (which lower 1"). The Espelirs may lower the front as much as 1.75" and rear as much as 1.25" from what the spring specs list. I know they sell rubber "extenders" which are supposed to add and inch, but then I figured they would defeat the purpose of getting a lower ride.
Now I am up in the air about even installing the springs! I wasn't trying to do it to be VIP'd out just for better handling and braking but if you tell me these will suffer I'm back to stock?
I value and appreciate your advice QTech, but please elaborate a bit more for and against lowering
