yeah i knowwhiterps13 wrote:A Town is a genius.
Ur not going to be able to adjust camber at all w/ our ruca's. Only by raisin the height of ur car will camber go +. W/ my coils i have been able to pull 6 degree's out of the fronts but thats just rediculous. Unless ur hardcore racer u dont need more then 3-4 degrees.jlwade wrote:Right front can be 6 degrees, right rear 2 degrees, Puts more tire on the track in the turns. That is why the oval track comment. I was hoping it would explain why anyone would want that type camber change.
i oculd have sworn there was adjustment on the camber arm....Atown 240 wrote:
When i go to DD's i use 3.5 degrees' Front and rear.
I dont think so, but if there is it probably isn't for more then .5 - .8 degrees. I'm pretty sure there isn't an adjustment though.yokota180sx wrote:
ad he is a racer, a circle track racer apparently
it work that well if you have the Tein Superdrift suspension?Atown 240 wrote:u dont need to take the strut off,
lift up car to get tires free, push in or pull depending on camber wanted.
Tighten.
