Cam Upgrade: What are your thoughts on this?
DjLiquid
Car: 1988 Nissan Pulsar
I got my hands on a set of 248's from a CA18DET. So now I have two exhaust cams. If I were to run 2 exhaust cams and take out the stock 240 intake cam, would it be a waste of time or would I actually see any power gain? I figured I would but I thought I would ask the guru's =)
89'ClubK's
Car: 89' Nissan 240SX
Never heard of running 2 exhaust cams, so I don't know really what gains or loss you would see. Are they going into a KA? I thought about the JUN cams for my CA, but then I was told by many people that it is a waste of time with a turbo engine. Mostly a NA upgrade. I would still figure that you'd see some power difference. Sorry if that doesn't help.
boost_boy
DjLiquid wrote:I got my hands on a set of 248's from a CA18DET. So now I have two exhaust cams. If I were to run 2 exhaust cams and take out the stock 240 intake cam, would it be a waste of time or would I actually see any power gain? I figured I would but I thought I would ask the guru's =)
It works and you will get some benefits from doing this, but don't be looking for no major increases. And please don't make a big issue about this guys! Dee
beans33
Car: 1993 ca18det 240sx
so by running two 248 Ca exhuast cams will provide some extra power ?Like Dee said I dont think its anything to keep going on about but, its something nice to know !!
DjLiquid
now by taking a look into this, it looks like the cam will need to be modified to make room for the CAS =/... Maybe I didn't look at it well enough but I may be wrong.
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
People started using double exhaust cams over here and now you can´t find a used engine with exhaust cam anymore... All the junkyards got open engines with dirt in the heads from people picking the cam and leaving it open.
I´ve tried it and no, nothing you can feel. No idea.
/Mike
DjLiquid
I just took a look at the engine and i got myself mixed up. The exhaust cam is the one with the crank angle sensor *knocks head* DOY! Thats no biggy now =).... The only problem I can see in the future is the a/f ratio. With a larger duration and more lift wouldnt it be true to say I should be adding a bit more fuel to my mixture to balance out the added air in there? I guess it's time to upgrade to a wideband O2 sensor and get my SAFC2 in there as well =)
float_6969
The nearly negligible amount of air that you will be adding extra will be compensated for by the stock ECU and MAFS.
DjLiquid
Swedish Mike wrote:People started using double exhaust cams over here and now you can´t find a used engine with exhaust cam anymore... All the junkyards got open engines with dirt in the heads from people picking the cam and leaving it open.
/Mike
buh? Im a little confused about the "No idea" part. Are you saying you've tried this mod and there is no difference?
I just want to clear this up before I start ripping apart my cylinder head =)
Thanks!
Swedish Mike
Thanks!
Correct, this became the new CA "thing" to do here a few years ago.Sometimes people do stuff just to do something, not because it makes any difference.
I´ve tried it and this mod sucks, you can´t measure any hp gain.The fastest stock head CA´s here still use stock cams, only newbie´s using exhaust cam now.
/Mike
dash
Car: s13 ca18
I think I remember reading that when using the exhaust cam it will be 9 degrees off or so ? SXOC forum has a ton of very detailed info on ca16/ca18 cams in DETs
