Cam types for RB25det
the_rock688
hi guys
i'm running an rb25det with stock valve springs and i'm curious to know what, if any, is the best cam to use and i'd also like to know which is the best cam gear to use with aftermarket valve springs ?
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
I'm going to beat everyone to the punch and just say Tomei PONcams. As far as I know, they are the main replacement bump-sticks people use. Jim Wolfe may have some, and RB26 may work.. (haven't looked into it yet). I know for a fact that Brian Crower has no intention of producing them, that is what he said to me on the phone a few months ago, but I bet with enough people asking for them he could start.
Cam Gear -- again, Tomei adjustable cam gears.
Try nengun.com, they have all sorts of JDM parts and accessories.
Search around, What are your power goals? I know ChaosTheXile has a high HP RB25, CarlH, BronzeMFP, etc. Just look around mang!
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
I'm running HKS cams and Tomei valve springs. Damn I love the sound of the idle.
If you have an RB25 please just get the exhaust cam gear. The intake comes with a few other issues that most people don't bother messing with. Once you get to tuning your ignition timing buy it, but before that I wouldn't bother with one. I have one, but haven't had a chance to tune anything with it yet. Looks cool, but until you tune it is pointless.
Chaos the Xile
Car: 1974 Datsun 260Z
Darius wrote:I'm running HKS cams and Tomei valve springs. Damn I love the sound of the idle.
Parden the thread jack, but Darius, what spec are teh HKS cams that you are using? Lift, degree etc...
the_rock688
i want number of came and number of valve spring
its 256 camshaft its ok in stock valve spring ??
how much stock rb25 valve spring left???
RB_Dreamin
l0nestar wrote:I know ChaosTheXile has a high HP RB25, CarlH, BronzeMFP, etc. Just look around mang!
Chaos' little nismoogle project is a joke. That thing isn't putting any power down. He basically lied about his dyno numbers and when Carl H called him out on it, he just let his thread die. I don't even know if he got it running.
Carl H
i personaly dont care for hks cams and would go with tomei, lopey idle isnt for me...i'd rather have a smooth idle with an evil exhaust note.as for bronze mfp having a high hp car, the motor is damn near stock (rb20) except for upped boost, 550cc injectors, and a tuned ecu i did up.
Darius
256 Duration and 8.8mm lift. Any more than 8.8 mm lift and you're looking at some head work to get the cams to clear the casting. When I installed mine I didn't think they would fit at first because it was so tight.
Chaos the Xile
Yea and any lift higher than 8.8mm, your gonna need to replace the valve springs or bad thinks can happen!
Darius
It isn't just your valve springs though. You will need to take material out of the inside of your head to allow that high lift cam to rotate. Otherwise it will try to spin once and end up snapping because it will run into the head before it even gets to the lifter.
Carl H
well anything more than 9mm of lift will require the use of a die grinder on the head to relieve it abit to clear the cam lobes...not hard with the head off the car but cams like that require solid lifters.
Darius
^^right on Carl^^
Chaos the Xile
WOW! Big balls! Its not my fault that the tuners computer had technical issues. But if you wanna see the HI HP taht I am putting down come on to Cincinnati and show me what you got agains a 427WHP RB25! TOOL!
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
yeah like carl said, my setup is pretty stock. stock turbo that i have a 14psi deathwish for, apex filter, 3" elbow, downpipe and exhaust, 550cc injectors and a light flywheel and thats about it. it's quick and its fun, but high HP it is NOT. still scares hona kids and puts new 350z's and g35's in their place though so i'm not complaining. And did I mention it's been 100% reliable for over a year now too? time to shut up, i think i may have just cursed myself.
RB_Dreamin
Chaos the Xile wrote:WOW! Big balls! Its not my fault that the tuners computer had technical issues. But if you wanna see the HI HP taht I am putting down come on to Cincinnati and show me what you got agains a 427WHP RB25! TOOL!
It's ok man. We all know you are lying. I mean anyone can say that they made xxx amount of power on the forums. But damn man, you even said it yourself, you really have no clue.
Chaos the Xile wrote:Look man I dont truly know what the issue was this is just what my tuner was telling me, I'm not as well verse in this like you are when it comes to ever aspect of the car, so when I get the right answer and the results and what happened I will let you know, so I can show you the power is real also the problems...
Chaos the Xile
RB_Dreamin wrote:It's ok man. We all know you are lying. I mean anyone can say that they made xxx amount of power on the forums. But damn man, you even said it yourself, you really have no clue.
I know its cool cause only d!ck pursuit something that they have no real knowledge of If you would like call Zerolift a shop in Cincinnati, OH ask for Dave and ask him how much WHP my car made and put it to rest man. Nobody is making a big deal out of it but you. Your prolly a 16yr old high school kid thats just dreaming of his license and that RB car that you wish you had the $$ to build!
GTR Shop
Car: 180sx RB26 T78, Y31 Gloria VIP + HEAPS of GTRs!
That spec sheet reads almost indentical to our RB25, but we have 264 cams in it and are making 603hp at the wheels on a hub dyno.Looks like you have a bit more work to go, or need a better tuner.....10.6 quarters to back it up in a std R33 GTS25t body.Dyno runs shoing 17psi, and the 19psi with cam gear changes.
