Cam timing
dkdeleon
Car: working on my car and playing my guitar
Can anyone help me with cam timing? ( Easyest way posible)thanx:help
DAEDALUS
Car: 1990 Infiniti Q45
Can you be more specific? These threads might help:
http://www.nissaninfiniticlub....14457http://www.nissaninfiniticlub....19841
dkdeleon
I am getting a tapping noise when driving, only when it is changing gears and no other time but then and rud told me I needed to adjust the cam timing
Aries
Car: LT1 240SS
well, cam timing is usually adjusted by rotating the cam gear/sprocket that the timint chain resides on while not rotating the rest of the assembly.
Open4Cycle
Are you wanting to know how to set the marks as from factory or how to degree the camshaft into close tolerances?
dkdeleon
all of the above
Open4Cycle
http://www.holley.com/HiOctn/T....htmlThis how to uses a V-8 push rod engine but this will give you what you need to know. The alignment marks I'm unsure of on a the KA24DE as I haven't had the valve cover off of my DE yet. The KA24E has 2 silver links that must align on each marked tooth of crank and cam sprockets.If you do this you will have a valuable learning tool.
Aries
Car: LT1 240SS
the DE has the silver links as well.
