cam
240sxboy223
Car: 1990 240sx
i have a 1990 240sx and i was wanting to put an aftermarket cam in it. want cam is best for it? thanks
Klits562
Car: white s13 coupe
Not alot of people make cams for the ka-e but i think nismo does google it n find out.
poshatch
Car: p.o.s. 1990 240sx hatch
i know this isnt what your looking for but i would say that it isnt worth the money for a cam swap save the money for something else a bit more useful
seang
Car: Ford Fiesta ST
Here is an exhaust video of a KA24E with a Nismo R4 cam, see the comments. http://www.youtube.com/watch?v=JKTKf078 ... re=related
Static compression is the most advertised, but dynamic compression is "what is really going on." Hotter cams like (or even require) higher static compression because the difference between it and the dynamic compression gets greater as cam duration (and valve overlap) increases. For example, an engine with a 9:1 static compression ratio will really have 7.2:1 dynamic compression, or something like that--dynamic is always lower than static.
Knowing this you can see why using a cam with too much duration on an engine with not enough static compression can drop the dynamic compression to a less than optimal level, thus less than optimal engine output/efficiency.
240sxboy223
Car: 1990 240sx
thanks for the info
