cam swap, this look right? I hosed it up please look
iitywygms
Car: 1993 sx se
I failed smog and asked around, some people said my intake may cam be retarded.
See this thread. 248-232-cam-swap-cause-lean-condition-t493848.html
Anyway, long story short. I redrilled a extra cam gear I had to advance the intake 2.5 degrees.
I am positive I drilled it correctly. I have access to a machine shop and high accuracy measuring machines.
I marked the timing chain and redrilled gear. Swapped the gears out directly, having to move the intake cam slightly because of the new redrilled cam gear.
Rotated the engine by hand and it felt okay. Fired it up and it idled poorly and make loud clicking noise. valve hitting pistons? oh no.
So, I looked around at pics of other cam swaps, looked at mine and thought that mine did not look quite right. Intake cam was at 10 o clock position while the exhaust was at 3 o clock. So I rotated the intake counter clockwise 1 tooth. Rotated the engine by hand, felt good so I fired it up. It runs pretty good, but I am not convinced it it right.
I don't know why I had to go the extra tooth. I am sure I marked stuff up correctly, but I obviously screwed something up.
So I took some pics for you guys to look at.
Do they look correct to you? It is at exactly top dead centre. I know pics are not easy to tell but please let me know what you think.
I still need to get this thing smogged.
lbreevesii
Car: S13 hatch LeMons project - Kaputzen!
BMW E30
1. the ticking is the chain slapping the tensioner. it will go away.
2. looks fine. I'm assuming you were running the 248 cam retarded 4 teeth, now -4 + 2.5*?
Running 3 teeth retard on a 248 cam makes it lope a lot at idle because its too far advanced. its also hard to time just right. Go try it out now with the redrilled cam. It bet she'll purr like a kitten. I know mine did. Best of uck on the smog crap.
How long have you had that car, and what oil are you using? looks pretty clean.
iitywygms
Car: 1993 sx se
I know that clicking sound, This was not it. It was louder.
I think it looks okay to. It runs fine all the way to 6.5 rpm. Still has a very slight miss/backfire at idle.
had it over 10 years. Penzoil full synthetic.
