Cam Swap and Trans Swap issues
RoBS.
Im going to be buying each of these items very soon so i need a 100% certain answer. I have a 95 auto and i want to swap to 5spd. Will an s13 trans work with this or do i need the s14 trans? I have also heard that swapping for the s13 cams will give me more power do the more agressive lobes. Is it the s13 cams in general or is it just the 91 cam shafts. Please need 100% answers because i will be purchasing this weekend. Thanks
Und3rprshUr
Car: My 300Z
95 auto what ?
base9se
Car: '95 240sx
Just 91 cams not s13 cams in general
brazymstrp
you can use a transmission from an s13, you would need the VSS from a MT s14 though, the s13 is different. You would also need the clutch hadlines that run from the clutch master cylinder to the slave cylinder. The Slave and Master cylinders. The clutch pedal assembly. The MT shifter shroud. Driveshaft. Clutch, and flywheel. Flexplate. And i believe on the 14, you need a MT Ecu. Save some time and cash by just using the same brake pedal, just cut it with a dremel or something. (Thats what I did) OH, almost forgot, you need the flywheel bolts and the transmission mounting bolts, as they are longer. Hope that helps.
I havent done the swap on the 14, but I have on a 13. It's pretty straightforward.
-Jack
