codyace »
https://forums.nicoclub.com/codyace-u28194.html
Mon Feb 22, 2010 8:42 pm
With C1 cams, you should use JWT springs, and OEM retainers/clips.
Duration of cams does not mean they are anywhere near the same. Lobe design, ramp rate, and lift are also huge factors.
You'd be best off using JWT springs (as suggest by both myself, and JWT) for your setup.
In regard to Ti retainers, they have a very high 'gall' ability, thus allowing them to deform and become weak through normal use.
