themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Wed Mar 19, 2003 8:26 pm
well torque is where it's at so when looking at dyno charts for parts ignore the peak number. You want parts that start giving you torque gains as soon as possible and as long as possible. A header would be good to get next and grab an extra cat and punch the guts out. Collector size and length can make or break you so don't rush out and buy the first one you see. Network, talk to as many people as you can find who either have or have seen dyno results of various headers. When you get one pick up some header wrap and mummify that sum*****. Keeping the heat in will increase the flow and keep your underhood temperatures low.Next get some longer bolts and washers and use them to raise up the tail end of your hood. This will scavenge the heat out of your engine compartment, I actually registered visible lower water temps after I did it. Every accesory on your engine's belt system is stealing ponys, remove the mechanical fan and score some electric ones either aftermarket or salvaged off another car, you should see increased throttle response, measurable power gains and if done properly lower water temps. Keeping in this vein if you can live without power steering do it: yank the belt, the pump, all the lines and cap the rack connections.If you have'nt replaced the fuel filter and cleaned out your throttle body do it, reset the computer afterwards to baseline the computer to erase any adjustments it may have been using to compensate for the plugged filter.Get an air fuel gauge so you can monitor it and a piggyback fuel computer like the Trust E-manage, Apex SAFC or HKS super AFR and richen up the mix for more power.just some things you can do.
