cam someone review my wiring. pics included.
fender-startocaster
Car: 1990 240sx
whats up guys. Just did a ka24de swap and havent been able to start it. Heres some of the doubts i have.
all wires are sodered, shrink wrapped then electric tape.
left over wires. they are all individuallt wrapped then wrapped in a bundle.
more leftovers^^ is it possible for the pins to be lose and lose contact?kind of read the diy wrong and cut of the whole connector. this is fine correct?dont know where this goes. any ideas?random engine shots. more random.
dana541
Car: 1990 240sx
dont mean to be a negative nelly here but.............twisting wires together and wrapping them in electrical tape is asking for all kinds of wierd electrical problems in the future.you should use some proper connectors and put heat shrink around them
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
dana541 wrote:dont mean to be a negative nelly here but.............twisting wires together and wrapping them in electrical tape is asking for all kinds of wierd electrical problems in the future.you should use some proper connectors and put heat shrink around them
fender-startocaster wrote:all wires are sodered, shrink wrapped then electric tape.
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
I know you have already, but just go wire by wire in the fsm. VERY time consuming but it will work. Theres a thread on here somewhere that has the pins into the ecu that do not need to be wired in.
fender-startocaster
Car: 1990 240sx
^^^ thanks i will continue to search. im just glad i got some responses lol.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
fuel lines are backwards homie.
the line from your filter needs to go to the side of the rail towards the rear of the car.
the line coming off the FPR needs to go to the line W/OUT the filter.
mrgreeneyes
Car: ///M5
The dash harness wiring is as follows.
Black - GroundBlue/Green - AC signalBlue/Black - water tempOrange - IGN startYellow/Red - TachYellow/Green - Speedo
Any wires other than those listed, DO NOTHING (for your purposes)
so
that being said... Black, Blue/Black, Orange are the only ones that REALLY matter to start the car. Double check the solders on them.
but your prob is MOST likely FUEL related, assuming i am seeing your pic right.
Modified by mrgreeneyes at 7:54 PM 11/11/2009
neverlift
also seeing a** backward fuel lines, maybe I am used to all that being deleted on my car.
dana541
Car: 1990 240sx
numbnuts240 wrote:
electrical tape is garbage,when it gets hot it will unwrap.connections will also corrode under the tape.im just a little fussy when comes to important wiring connections,especially when its wiring going to the computer.just an opinion though
mrgreeneyes
Car: ///M5
if you buy s***ty e-tape, it will be s***ty.
i only use premium stuff (3M pro grade or Plymouth) and have NOT ONCE had a problem.
heatshrink is a PITA and unnecessary IMO...
but what do i know... i only worked in (and later managed) an audio shop for 5 years...
fender-startocaster
Car: 1990 240sx
mrgreeneyes wrote:fuel lines are backwards homie.
ahhhhhh!, cant believe i did that. and to know i had them correct the first time lol.
Im actually using 3m electrical tape. It costs me $4. at target :/
Anyway thanks for all the help. The car starts now but dies shortly after.
