Ajax »
https://forums.nicoclub.com/ajax-u5731.html
Fri Mar 12, 2010 12:52 pm
one bajillion power units.If you're still needing to pass smog, your best bet would probably be to stick with the stage 1. Stage 2 would probably only net you an extra 8-10 peak hp at best and you would most likely fail smog. You could ask PDM to see if they've dynoed them in comparison (similar to their DOHC offerings).Since you don't know how to mill towers, you'd need to take it to a shop- keep that in consideration too.
Edit- wait, does CA smog apply to 20 year old cars?
