Cam Shaft Sensor P0345
ProverbPsalms
Car: 2006 M35x - Graphite/Black, Journey, Tech
2011 M56x - Black/Java - Deluxe Touring, Premium, Tech
Hello,
I know many threads have been made about this, but which Cam Shaft Sensor needs to be changed?
I understand there would be two different ones, in my 2006 Infiniti M35X - Which one would be causing the check engine light, VDC and Slip to turn on, I added brake fluid oil, and that did not fix the problem, I work in sales in a Cadillac store, and they checked with the scanner, and I got the P0345 code.
Ilya
It's likely whichever one is on bank 2, according to a quick Google search. Forget which side of the motor is which bank, but I'm sure someone can chime in with that info soon.
Costee
Car: 2006 Infiniti M45 Sport
2012 Nissan Murano SL
ProverbPsalms wrote:Hello,
P0345 is for Bank 2, that's the driver's side for M35. For the VDC and Slip lights you'd need a tool that can scan the ABS. It just could be that your steering angle sensor needs re-calibration.
gavnator
Car: 2006 Infiniti M35X Obsidian Black, Bourbon Interior, Journey, Navigation
2013 Mazda CX9 Grand Touring
my 2006 M35X failed on 3/2015 at 69,800. P0340 Bank 1. Took it to Infiniti for replacement. Camshaft sensor failures are pretty common on the 3.5 v6.
