Just to clarify, he said that 240/232 was good for automatic 240's. His overall pic was 248/232. Although in a recent thread, he was asked if he still was a fan of the 248/232 swap and he said no. He now prefers the stock 240/248.neverlift wrote: I have stock 91 cams already in the motor 240/248, I read through djpantspecr's cam reflection thread(a hundred times), and the man said 240/232 is the best overall in his opinion, and is good for people going boost.
Everyone I've talked to that has experienced stock vs 248/232 vs 248/248 say that the topend 248/248 gives you isn't worth the low end and mid range that you lose going from 248/232. This is what I understand from N/A ka'sWDRacing wrote:I'd use the combo that provided the most flow...248/248 or 240/248. But never 232...WD
Tuning for NA and tuning for boost is entirely different. Things like back pressure and boost threshold come into play with the KAT.simmode1 wrote:
But with a boosted application, the turbo can recoupe the low and mid range and the top end from 248/248 will be even more beneficial.
But I guess we'll never really know until some publishes dyno results of each oem cam swap and aftermarket ones both in N/A and boosted versions.
Low end torque with a 4 banger is easy to lose. It's also the most note-able when lost or gained, since just a little seems like a metric ton. But I'll bet dollars to donuts that you'll make a ton more power running 27psi if you remove that tiny exhaust cam.spank044 wrote:248/232 (int) +2.5 FTW!
I had 248/248 with different degrees on both and then switch back to 248/232 and was immediately impressed allover again. Also I had more noticable power in the bottom end and I didn't stall under decel. I'm running 27 psi on a Hybrid K27 T3/TO4E with 650CC RC, custom 3.2 liter intake manifold, no emissions or IAVC, etc. I should do a build thread, but maybe this winter. Butt dyno and passengers are fully impressed and so are the cars I have dominated so far. On the local drag I run low 11's with the 248/232 and ran 12's with 248/248 just because of the bottom end. No dyno's to show HP differences, but they are there in the bottom end for sure. IMO rock stock S13 cams or the 248/232 (int) +2.5.
If you just want someone to tell you what you want to hear then I can tell you anything you like bro...doesn't make it a reality.simmode1 wrote:Thanks, spank044. I think thats what the op and I were wanting to hear.
You're always so touchy! I don't think anyone suggested that running oem cam was the best option for anyone. The op just asked for a comparison between the two oem setups.WDRacing wrote:
Spanky is running 27 psi...so yeah, he makes power...has NOTHING to do with his cam selection. Running that much boost and using a 232 cam and claiming it's the best option is like winning the special Olympics...yeah, you won...but you're still retarded.
Word to that. It is all about where you want your power. Next year when I am launching on the hose I will probably put 248 +2.5/ 248 -2.5 back in or buy 264's to utilize the top end crazy power, but right now I need my power onset to be in the low end.simmode1 wrote: From all that I'd read about cam selection, biggest isn't always best. It depends on where you would your powerband. Modified by simmode1 at 12:36 PM 9/30/2008
Quote of the month right there.spank044 wrote:I'm not retarded!!!!........
I do have the DIY adjustable cams on both int and exh and have tried many degree combos. I even got so far out I needed all new exhaust valves.
Read that article I posted a link to.neverlift wrote:wd I understand what you mean more cam lift/duration is a part of making more power, but so many have stated they loved the pull of the 248/232.
With the overlap of the intake, they're sucking in more air earlier and not forcing enough air out. Depending on the degree they use it can actually have some of the spent charge stay inside the combustion chamber.
It IS possible they make more power this way because they aren't burning all the charge on spark I think. This would make the motor run a little bit leaner and possibly produce more power. I'm not 100% of that statement though. If that is true, it means that their ignition system isn't up to par, which is probably true when you think about the stock ignition setup and what abuse a KA-T gives it.
I'm not trying to argue or anything, I just want 100% solid proof that flowing less air into a motor can be a good thing. It just doesn't make sense to me.
Same here. I actually first started looking into it because of this thread. It looks like something very interesting. I'm looking at some 'Stage 2' cams from different companies and it looks like they use the same or very similar cams on I/E on DOHC motors. I wonder if this is for performance or to save money/make the parts cheaper. The higher 'stages' tend to be a little different I/E...480sx wrote:Idk i need to learn more about duration/lift, and mostly overlap before i can really add much if anything to this thread.
Yeah. We need something like that camshaft mega thread they got over in the SR forum. Or somebody write to Modified Magazine and ask them to do our homework for us...DevilMB3017 wrote:Lots of unanswered questions, lol.
