jrc90240sx »
https://forums.nicoclub.com/jrc90240sx-u355.html
Tue Aug 12, 2003 6:12 pm
Also Cam Sproket (gear, pulley) is what rotates and times the cam to the crank. an ajustable cam sproket alows you to advance and retard the cam timeing (difrent then ignition timing)
a returned ECU will not be drifrent weather you have boltons, or cams. the only time they change it is for changed compresion ration, larger injectors, larger MAF, FI, transmission (auto-manual), and N20 maps. there might be some others.
