You must remove a whole lot more than just the front cover to look at the sprocket on the crankshaft
So that's why I'm looking for an easier way out. Since every part of the chain is the same it should be ok to turn the enigne until TDC and then adjust the cams according to that.
When I compare the pictures on thess two URL'shttp://sr20.hybrids.jp/install...3.jpgandhttp://home.no.net/reffer/head_gasket.htm
I'm pretty sure that I have got it right this time. If somone dissagres PLEASE let me know
