DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Mon Feb 17, 2003 9:03 am
The first thing you should do is a compression check on each bank. It won't certify your timing is correct, but it will tell you if it's off.Aren't there markings (dowel pins and/or indentations) on the cam sprockets that match up with colored links on the chain? They probably won't mactch up exactly, but the number of links between each colored link and the related sprocket marking should be the same. Of course, to be absolutely certain, you need to see the crankshaft sprocket too. Aren't the #1 and #3 cylinders on the same cam? That is, what does it matter what the #3 intake cam is doing relative to the #1 intake cam? I've worked on engines but I'm not intimately familiar with the 240 in particular.
