Cam HELP!!!!!! Please
Florida240sx
Just took my valve cover off and found this...Think I've found my issue...I hate cams and need to know what i should do. Intake is off correct? So I need to loosen intake cam bolt turn sprocket once and turn cam to correct position and then tighten?
DRFT(kinda)
Car: 2005 Nissan Titan.
Actually, i dont think it is off. but i could be wrong.
Florida240sx
I hat cams, but this has to be the problem it might just be off a couple degrees... Need a cam install expert's opinion on what to do.
coolbone28
ya try and take a pic of your exhaust cam too. i actually think that one is too low.
Florida240sx
There is.. one of intake one of exhaust...
coolbone28
well from the angle of the pic i would say its a little too low. and your intake side might be just slightly too high, but the main thing is they are not symmetrical. when I was setting my timing the cams would come to rest at the right spot basically. and when you turn them they would have resistance, but wanted to spring back to their resting spot. just try lowering your intake a hair and then matching your exh. side to that.
nvrplzd240
Car: 04 G35, 02 CBR600 f4i, 90 Sentra
swap to an SOHC
only 1 cam to hate
Florida240sx
nvrplzd240 wrote:swap to an SOHC
only 1 cam to hate
Will someone with helpful information respond.Do I need to take the sprocket off? Just loosen the cam bolts and rotate the cams a bit and then retighten? What should I do?
TheOne
Car: 93 240sx FB
tho i believe you couldn't have swapped intake for exhaust cam, i think those cams seem fine?(so long as the big sproket isn't off with the crank, the sproket that goes on the head, have you checked that?, if all the alignin dots are on their place with the timing chain, then you should be ok unless they're switched in the V2 cams, which i doubt)
coolbone28
to adjust them put the engine at TDC. take out the cam sprocket bolt and only do 1 at a time so as to make sure that the chain doesnt move on the idler sprocket (lower one). take off the sprocket and turn the cam with a wrench. then just put the chain on the sprocket and then put them on the cam. it can be a little tricky becasue there should be tension and of course there is not alot of slack to play wiht. so once you get 1 set then do the other.
coolbone28
http://jimwolftechnology.com/w...E.PDF
2nd page has a good example of the positioning
Modified by coolbone28 at 2:20 PM 12/10/2006
nissanfanatic
Car: 1992 Nissan 240sx SE
No matter what, you are gonna have to take it all apart to retime the engine... Unless you take a lot of time turning the engine over until everything is lined up perfectly.. I would just retime it... It won't be too bad..
Florida240sx
I need to get a pulley puller......Just rotated the intake sprocket back 1 and lined the cam up.Car pulls nicely in top end now BUT I have absolutely no power down low... Vac is at 10-12. As soon as I hit around 4000rpms the car picks itself up goes and pulls to redline.Could this just be a re-adjustment of the cams?
KATwo40
Car: 1993 240sx KA-T
Ok, here's the deal.
First off, you don't have to take the whole set apart. Trust me on this, and follow my instructions, and it all works out great.
Your intake cam is off, that's for sure, by one tooth.
Ok, here's the easiest way to do it.
1. Make 100% sure that #1 is at TDC. Use the timing marks on the crank pulley to do this.2. Lock the upper tensioner back so that it's off the upper chain (use a push pin, thumb tack, paper clip, etc.).3. Remove the intake cam gear bolt.4. Very carefully, pull the intake cam gear off the cam, but not completely out of the chain. 5. Hold the chain with one hand so that you can rotate the intake cam gear COUNTERCLOCKWISE one tooth.6. Slide the gear back onto the cam and install the bolt.7. Check to make sure that the chain has slack only on the passenger side, near the tensioner. The upper portion and the driver side portion should be fairly tight.8. Pop the tensioner pin out and let it snap tight against the chain.
There ya' go, buddy. I just went through this on two different cars and I got it all straightened out this way, no problem.
KATwo40
Well, I see that my post was too late.
Sounds like your ignition timing is off. Check it.
Florida240sx
I had to turn the sprocket once because of the cam dowel pin.... Turned the cam until it lined up..... However when I was tightening the cam bakc up there was slack inbetween the cams from pressure. So need to get that fixed... Read my above post for current issueSo you think then my base timing is messed up now? I have to get my timing gun tomorrow from work.
KATwo40
If you had the front cover off, it's possible, since the distributor was out.
Either that, or the pair of cams is off from the crank index. Put the crank at TDC via the marks on the pulley (second mark from the left) and recheck the cam index to be certain.
nissanfanatic
Just use the FSM...
BTW, it looks like the dimples on the cam sprockets are lined up with the gold links..
Florida240sx
nissanfanatic wrote:Just use the FSM...
They are were should they be?JWT site confuses me.I can't find any FSM's been searching for a while. And everytime I try to download one online the link is bad.
crzycav86
Car: 93 Nissan 240SX KAT
That's what I was thinking, but the cam lobes look like they're oriented the wrong way relative to each other(at least I think they are)... so I'm just confused.
I'm not sure... but maybe the lower chain is the one that skipped a tooth.
Florida240sx
I've rotated the intake so now the cams face opposite. I'm going to start a new thread tomorrow.* Current issue is I have no low end power at all. Vaccum is -12.*
PapaSmurf2k3
Site Admin
The cam lobes on cyl 1 at top dead center should face opposite each other, paralell to the ground, at least that is what I got told when I was doing mine, so by your first picture it looks like your intake cam was off by 1 or 2 teeth. Its such a ***** if you dont do it all at the same time and use the marks on the chains, cos then the marks are useless and just there to piss you off.
gaehrings13
Car: Nissan S14
I try my best to use the marks on the chain, and make sure you tdc is set from that second mark like katwo said. Make sure your rotor and all you wires are good on your distributor.
Florida240sx
Process of cam fix #2.... I didn't even touch the cams... I took pics though... I'll find out in about an hour, if the issue has been fixed...
Florida240sx
Problem not fixed new thread to be up.
sunnys14
Car: S14
can u take pics from a top view so we can see where the front lobes are point @ TDC?
sunnys14
Car: S14
if u really want to make sure if your cams are right, do what i did. i just took off the front upper timing cover (additional 8-10 bolts, another 10 mins of your time) and RETIME the complete upper chain when @ TDC. realign the colored mark from the upperchain with the main sprocket notch. then retime the cams with their appropriate marks. trust me, it only takes another 15 minutes just to MAKE SURE you have your cams right.
