cam help !! asap
beans33
Car: 1993 ca18det 240sx
I am putting my intake cam back in and after tightening all the caps down in order, the cam wont turn at all to set the timing. I did the exhaust cam the same way and its fine. If I loosen the caps up to about finger tight the intake cam will turn just fine. If anyone can help me I would appreciate it. thanks
silvia_ca18det
Car: 350whp ca18det drift silvia
did u use asembley lube? how hard are u trying to turn it? and is ur head off the block?
beans33
nevermind I changed out the caps from some of my other ca parts and they worked fine. The cam turns perfectly fine now. thanks
sideways danny
Car: s13, CA18DET
oh my god!!!!!!!!!!!!!!!
the caps are specific to the head, they're line bored on the head, you can't swap them about
tyrannix
Car: go big or go home
they should be numbered and labeled I or E (intake, exhaust)
just wipe the tops and look at them, theres only one way to make them look right, start with the caps on the front(right behind the cam cogs) , then make the rest go the same way
