Cam for a SOHC KA24E
Iamjohnhayes
Car: 89 Single Cam Hatch
I am planning on doing a cam swap in my 89 S13 and was wondering if this cam is worth buying. It's made by Comp Cams and I can get it for about $120. It sounds a little cheap to me. I was also wondering if anyone could give me the specs on the stock KA24E cam.
Intake Duration 050 inch Lift: 214 Exhaust Duration 050 inch Lift: 214 Duration at 050 inch Lift: 214 int./214 exh. Advertised Intake Duration: 260 Advertised Exhaust Duration: 260 Advertised Duration: 260 int./260 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.420 Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.420 exh. lift Lobe Separation (degrees): 110 Intake Valve Lash (in): 0.000 Exhaust Valve Lash (in): 0.000 Computer Controlled: No Grind Number: NZ 260S
sticky240
Car: 90 240sx, 04 Titan SE
I think thats a mild cam. According to PDM's site that should be good for a stock engine
their second listed cam is Intake 268 degrees duration, .441 valve list, Exhaust 272 degrees duration, .447 valve lift.
on their site it sayd its a strong performer with good midrange pull to redline. THe only thing you have to do is mill the cam towers .25"
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
Where are you going to get a cam that cheap. The only cam i found is 300. Please give me the site, **** i might want to buy a cam too.
Iamjohnhayes
Here's a stupid question:
Why exactly would i have to mill the towers?
And Nelson I just searched Summitracing.com for my year 240 and they give you a load of parts for pretty cheap.
