MiniMan »
https://forums.nicoclub.com/miniman-u11995.html
Mon Oct 11, 2004 5:51 pm
911/Q45, thanks for that. I'm still getting used to the new search page setup. Turns out I should try searching through bodies of posts instead of titles. Appreciated.
Paul Zigouras said there is about 70hp to be gained by doing an N/A build up without cams (porting, polishing, raising the compression, etc). He also said to expect well over 400hp by going with aggresive cams on top of the build up. Anywhere from 410-420hp at the flywheel is expected.
Is there a market for it? Well, as with all things Q45... I doubt it. Maybe for a few people, sure... but not many.
Is it feasible? Dennis says:
Quote »The interferrence of the valve and piston [already have flycuts in piston] means no more lift can be used without new pistons. And 0.490 with a 1.5" diameter valve is already ultra high lift and is perfection for valve curtain area vs valve seat 5 angle cuts.
Cams won't help much because the runners and plenum is tuned to 4,000, 4600, 5600, and 6,000 rpm. Figure out a way to shorten the runners by 2-3" and increase their opening diameter [area] by 8-10% [and maintain the taper ratio] and you might retune the engine to a 6800 rpm HP peak and yield aroud 350-360 HP unfortunately you would lose so much torque at 55 mph cruise that you would have to bump the diff gear up by 25%..........to let the heavy Q cruise with AC on.[/quote]With having the engine built up w/cams, I doubt you'd notice a difference down low... but when you got up into the higher RPMs... I bet she'd be unreal. Having power down low is nice for daily driving, but REALLY showing an M3 whose boss on the highway is another thing. It's a trade off I guess and depends on what we'd want to do with the cars.
Corey
