CAM chain TENSIONER LOCATION!
MIKEL240
Please! Does anyone here know where the CAM chain TENSIONER is located? I'm having trouble locating the tensioner, please someone show me EXACTLY where it is located! PLEASe, anyone here with some pictures???Anyone can help!!!
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
The cam chain is basically an upsidedown triangle. The tensioner is on the bottom left side.
MIKEL240
Can anybody point out the cam chain tensioner on the picture? Please this is the only probelm that I have with my install of the cams. Please circle the TENSIONER on the picture! Thanks and here's the picture.
BadMojo
Car: 2007 Mazdaspeed 3
Tensioners look like this. I don't really see it in your pic, but here it is.
http://www.courtesyparts.com/M...00003
Edit: Minus the thumb tack, of course. :D
leper421
Remove the front upper timing cover, and you will see it.
latergator
Here, look up in the top left of the picture, above the upper timing chain, which is also your cam connecting chain. There you will see it, (upper timing chain tensioner). Good luck...
neekap
In the picture, the tensioner is near the left side about halfway down, right behind the timing chain, you can see a little metal edge of it as circled in the picture.
