Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Sun Mar 28, 2004 11:49 am
Hmmm... I dunno too much about the DE motor, owning an 89, but here goes...
There should be a tensioner somewhere in between the idler gear and the cams (I think it's on the left side but I'm really not sure) and you should be able to find it by following the chain from the idler to the cam sprocket.
You might be able to push in the piston inside the tensioner using a clamp in order to give you enough slack to pull the cams out. I know you can on the E, so I think you can on the DE too.
