cam angle sensor(cas) install
xero1
Car: 08 Altima Coupe
i did a search and couldn't find any instruction on how to install the cam angle sensor(cas) correct. is this correct, set crankshaft pulley to 0 degree mark TDC and install cas with dots line up?
Gramentz
Car: s14
FSM! Enthalpy's site tells you how to set the timing as well. Heavy throttle is another site that shows you how.
b0rdin4life
Car: 95 240sx
try this post.... zerothread/193680
or this link.... http://www.frsport.com/sr20det....html
Between those two links I was able to get mine set correctly.
