SimpleEnigma »
https://forums.nicoclub.com/simpleenigma-u14504.html
Fri Nov 18, 2005 2:02 pm
I dont think you will ping with 91 octane, so long as you keep the ignition timing at stock, they sell only 93 octane where i live, so i dont know if there is a great deal of difference. I do know that there are a lot of crate engines that run 12:1 CRs and some motorcycles run a 12:1 CR on pump gas with no problem.
As DJPants said, you shouldnt have valve clearance issues, since the '91-'94 cams all have the same lift, just a longer duration than the S14 cams
the E pistons are a direct swap, no mods necessary, and one of the guys on this board sells them and the rings in standard size and .040" OB which is what i am planning to run.
