Cam and Crank Sensors SR20det HELP!!!!
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
i have a 92 s13 hatch with a s13 sr20det. the rpm in the cluster hasnt worked since i bought the car ( the swap was already done) and to avoid all the labor and with advice from a trusted shop i got a clean 3"autometer tach. after i put it in, its not giving good readings and is jumping around alot, the tach is fine... but im pretty sure the crank and cam sensors are broken and thats why im not getting a good reading. i have done the google search and havent found much, so i want to know if anyone knows anyone who sells the sensors for the s13 sr20det, or any advice with my situation. thanks
Justin35ll
Car: s13 coupe sr20det
What crank sensor
Wretched
Car: 93' Hatch
does your car run? if yes, you're cam sensor is most likely not the issue. check your wiring. and let me know if you find a crank sensor
badbob2121
Wretched wrote:does your car run? if yes, you're cam sensor is most likely not the issue. check your wiring. and let me know if you find a crank sensor
yes the car runs amazing... i know there is some wiring issue in the wiring harness keeping the cluster rpm from working... but its a temporary and cheaper solution runnning an external tach... and i was told the readings were coming bad from a broken cam/crank sensor... i dont know which sensor... not sure if its the angle sensor etc ... never had to deal with an issue like this before..
