Calsonic CWV617 a/c compressor 240sx and Q45 ?
Mr.Q45a
Car: 1994 Q45, 1995 Q45a
Hi
I have been researching a a/c problem and during that investigation I found that the Nissan 240sx uses a Calsonic CWV617 which is the same compressor installed on the 94-96 Q (please refer to: http://www.aircoparts.com/).
I found this interesting because the 240 is a 2.4 liter and the Q is a 4.0 litter.
Further, most of the posts on the subject indicate that the 94-96 Q’s have tremendous cooling power.
Is this possible ?
Has there been a scriveners error?
Any other thoughts?
Best regards,
Q45tech
Since variable displacement compressors are self regulating based on charge weight [and low pressure feedback control], the volumes [areas] of condensers/evaporator set the BTU capacity.
The amount [area] of window glass and insulation are variables ------both vehicles could hold 4 people [constant heat load].
Typical small car AC runs 15-24,000 BTU/hr whereas lux sedans can approach 36,000 BTU when brand new.
http://www.babcox.com/editorial/ic/ic50350.htm
For those engineers here is the heat mass transfer coefficient of R134ahttp://www.sae.org/altrefriger...r.pdf
Mr.Q45a
Hi Qtech:
The information you provided was informative to the highest degree and on the point. I appreciate you taking the time to answer my questions.
Thank you,Quash
