Calling out the BG product lovers!!!
gammer_ghn
Gooood morning!!!! Ahhh its Sat and its time to pamper the Q = ]
So my question here is that if i use the trio willl it be a bigger difference in cleaning up the Q or the trio is just a way for them to make more money and if BG44k alone is enough?
thanks a bunch!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
BG44K goes in the tank, so it is easy.
The intake cleaner relies on a fogger device and the injection cleaner relies on a injection rail attachment.
Q45tech
I use 4 cans of 44k and 2 cans each of the other 2 annually and have for the past 10 years. Plus at least 4 MOA and assorted diff additives and ac products.
There are other BG products more rigorous and dangerous to the layman. Things just short of a pure ACID. BG ISC requires a respirator and breathing oxygen in a closed garage
gammer_ghn
maxnix wrote:BG44K goes in the tank, so it is easy.
well I took my car to a BG shop which was an Infiniti dealer in my area no fogger was used he sprayed and cleaned it and no injection rail attachment was used the guy did it through my Brake booster but he did it with a BG machine thingy and he did a scan on the scanner to see if anything was wrong with the car and nothing came up and i told him about the oo soo controversial VVT control screw and he adjusted it for me for freehttp://i22.tinypic.com/2iqmk8w.jpg
but this whole thing ran me $50 but it was paid directly to him under the table or tools drawer if u want to know exactly soo did i get it in the or that’s how it supposed to be done. I was amused that they didn’t use the BG 9210 Inject-A-Flush Apparatus i was looking forward to seeing it but nada... its easy to do the way the shop did it i can do it my self so i dono any info would be marvelous!!!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Read Q45tech's rail flush posts to see how it is to be done.
Fogging is good maitenance to keep a clean system clean but won't clean a seriously dirty one. Does nada for the injectors. Only the rail flush does along with BG44K as the final in the tank additive.
Modified by maxnix at 8:20 AM 11/11/2007
gammer_ghn
Thank you sir = ]
